The 23" Full HD model sets a new milestone in IPS display technology. The fantastic design offers extensive connectivity options, such as D-Sub, two HDMI connectors and a DisplayPort. Its practical MHL interface allows you to hook up your Android mobile devices directly to the monitor. These monitors are known for vivid colours as well as high viewing angle stability. The display comes with a 250 cd/m² brightness, a typical contrast of 1000:1 (dynamic contrast: 50,000,000:1) and a 5 milliseconds response time for your ultimate viewing experience.
IPS Panel
No matter if you are viewing photos, videos, a magazine layout in InDesign or playing your favourite game – we want your content to look excellent from whatever angle you are seeing it. That is why this display comes with an advanced IPS panel, which produces brilliant colours and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you – or your friends and co-workers sitting or standing next to you – are looking at the screen. -
Integrated Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers. -
MHL Connection
Mobile High-Definition Link (MHL) technology lets you mirror the content from your portable devices directly on this display. Use an MHL cable to connect your smartphone or tablet and bring all your entertainment to life on the large monitor screen with full digital sound. Relax and enjoy your games, movies, photos and apps on the big screen while charging your mobile device at the same time. -
IPS Panel
Display Port
The most recent display interface standard from VESA, DisplayPort can also transfer audio, USB and other forms of data. DisplayPort version 1.2-1.2a support up to 165 Hz@1440p, 75 Hz@2160p, version 1.3 supports up to 240Hz@1440p, 120 Hz@2160p and the version 1.4 supports HDR10 specifications.
- AOC I2369VM - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class B
- Energy Consumption per Year
- 29 kWh
- Power Consumption (On mode)
- 20 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, VGA, DisplayPort
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- 53.14 cm x 20.4 cm x 39.8 cm
- 4.89 kg
- Environmental Standards
- ENERGY STAR Qualified
- GOST, FCC, RoHS, TUV Bauart, ISO 9024-307, EuP, NRTL
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 29 kWh
- Diagonal Size
- 23"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Eco-Mode, i-Menu, e-Saver technology, Mobile High-Definition Link (MHL), Screen+
- 4.89 kg
Audio
- Speakers
- VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 75 x 75 mm
- Power Supply
- Internal
- Input Voltage
- 20 W
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
