Your basket is empty
AOC 19" E960SRDA VGA DVI  with Speakers
Quicklinx: 9179WS00 Mfr#: E960SRDA
This model targets business and home office users alike. Hidden behind its classically designed case is the latest LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance.
With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured black finish.
AOC Professional e960Srda - LED monitor - 19"
LED-backlit LCD monitor - 19"
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Black with hairline texture
40.92 cm x 21 cm x 40.51 cm
2.85 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, FCC, RoHS, TCO Displays 5.0, EuP, NRTL
3 years warranty
Display Type
Diagonal Size
19"
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Video Bandwidth
140 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Eco-Mode, i-Menu, e-Saver technology
2.85 kg
Audio
Speakers - stereo - integrated
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable
16 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
Included Software
Drivers & Utilities, I-Menu
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
9179 C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £6.67
9179 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.46
9179 C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £10.14
9179 C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £8.34
9179 C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
9179 C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £35.16
9179 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £7.07
9179 C2G Pro DVI-D to VGA Converter - Video converter - Black In Stock £47.40
