For system builders old and new, the VSK3000E is the simple, reliable and cost-effective solution for your home or office. The VSK3000E is designed with durable, galvanized steel construction and is Intel Thermally Advantaged Chassis (TAC) 2.0 compliant to ensure stability and excellent cooling for all your system builds. With support for motherboards up to microATX, the case also supports 12.5" graphics cards. In addition, the stylish front panel is equipped with two USB 3.0 ports, Audio In/Out jacks and other computing essentials. If you're looking for a simple, reliable case that won't break For system builders old and new, the VSK3000E is the simple, reliable and cost-effective solution for your home or office. The VSK3000E is designed with durable, galvanized steel construction and is Intel Thermally Advantaged Chassis (TAC) 2.0 compliant to ensure stability and excellent cooling for all your system builds. With support for motherboards up to microATX, the case also supports 12.5" graphics cards. In addition, the stylish front panel is equipped with two USB 3.0 ports, Audio In/Out jacks and other computing essentials. If you're looking for a simple, reliable case that won't break the bank, the VSK3000E fits the bill.
- Antec VSK 3000B-U3/U2 - tower - micro ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- I/O Connectors
- 1 x USB 2.0 , 1 x USB 3.0 , 1 x microphone , 1 x audio line-out
- Supported Motherboards
- microATX, Mini-ITX
- System Cabinet Features
- TAC2.0 (Thermally advantaged chassis version 2.0)
- Power Device
- No power supply
- 17.3 cm x 39.3 cm x 36.5 cm
- 4.1 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- Micro ATX
- Internal Bays Qty
- 3
- Front Accessible Bays Qty
- 3
- Product Material
- Steel
- Cooling System
- Rear: 92 mm fan x 1 / exhaust , Front: 92 mm fan mount x 1 / intake
- Video Card Max Length
- 318 mm
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" , 1 (total) / 1 (free) x front accessible - 3.5" , 2 (total) / 2 (free) x internal - 3.5" , 1 (total) / 1 (free) x internal - 2.5"
- Expansion Slots
- 4
- 1 x USB 2.0 , 1 x USB 3.0 , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack
- RoHS
- Power Device
- No power supply
- 17.3 cm
- 39.3 cm
- 36.5 cm
- 4.1 kg
- Limited warranty - 2 years
