Antec VP400PC Power Supply (Internal) AC 230V 400Watt
Quicklinx: CMM1WS00 Mfr#: 0-761345-06487-3
Power Rating: 400Watt
£27.66 ex VAT
£33.19 inc VAT
Antec's VP PC power supplies promise one thing: quality performance at an incredible value. This entry-level solution gives you everything you need in a power supply, and nothing you don't. No bells. No whistles. No nonsense.
Antec VP400PC - power supply - 400 Watt
Power supply - internal
1.41 kg
United Kingdom
Input Voltage
AC 230 V
Power Capacity
400 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 3 x 4 PIN internal power , 4 x 15 pin Serial ATA power , 1 x 6 pin PCI Express power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
United Kingdom
Input Voltage
AC 230 V
Frequency Required
47 - 63 Hz
Power Capacity
400 Watt
Output Current
+5V - 18 A , +3.3V - 22 A , +12V1 - 18 A , +12V2 - 17 A , -12V - 0.3 A , +5VSB - 2.5 A
Efficiency
82%
Cooling System
120 mm fan
Thermal monitoring, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, surge & inrush protection, no load operation & brown-out protection, CircuitShield
CB, CCC, RoHS, Energy-Related Products (ErP) Lot 6
1.41 kg
Shipping Width
26 cm
Shipping Depth
12 cm
Shipping Height
21 cm
Shipping Weight
1.75 kg
Brand: Antec
Price Range Ex VAT: 0 - 50
