Product
Antec TrueQuiet 14cm Case Fan Dual Speed Silicone Grommets
Quicklinx: 9PKFWS00 Mfr#: 0-761345-75260-2
Antec's TrueQuiet fans bring proven cooling and Quiet Computing to your system. Constructed for versatility, TrueQuiet fans include a convenient 2-speed switch that allows you to easily choose either silent or maximum RPM cooling. Because a functional computer relies on more than just cooling, TrueQuiet is equipped with silicone grommets and a uniquely-designed fan blade to reduce turbulence, vibration and noise for overall quiet operation. Upgrade your fans and add optimal cooling and functionality to your PC with TrueQuiet.
Antec TrueQuiet 140 - case fan
Case fan
Fan Diameter
140 mm
Fan Height
25 mm
Rotation Speed
500/800 rpm
Air Flow
20.3/32.4 cfm
Noise Level
9.8/20 dBA
Power Connector
3-pin plug, 4 pin Molex connector
14 cm x 14 cm x 2.5 cm
173 g
Fan speed monitoring
2 years warranty
Case fan
14 cm
14 cm
2.5 cm
173 g
Heatsink & Fan
Fan Diameter
140 mm
Fan Height
25 mm
Rotation Speed
500/800 rpm
Air Flow
20.3/32.4 cfm
Noise Level
9.8/20 dBA
Power Connector
RoHS
2 years warranty
