Antec's TrueQuiet fans bring proven cooling and Quiet Computing to your system. Constructed for versatility, TrueQuiet fans include a convenient 2-speed switch that allows you to easily choose either silent or maximum RPM cooling. Because a functional computer relies on more than just cooling, TrueQuiet is equipped with silicone grommets and a uniquely-designed fan blade to reduce turbulence, vibration and noise for overall quiet operation. Upgrade your fans and add optimal cooling and functionality to your PC with TrueQuiet.
- Antec TrueQuiet 120 LED - case fan
- Product Type
- Case fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Rotation Speed
- 600/1000 rpm
- Air Flow
- 21.1/46.3 cmf
- Noise Level
- 8.9/19.9 dBA
- Power Connector
- 3-pin plug, 4 pin Molex connector
- 12 cm x 12 cm x 2.5 cm
- 138.9 g
- Adjustable speed, red LED lighting
- 2-year warranty
- Product Type
- Case fan
- 12 cm
- 12 cm
- 2.5 cm
- 138.9 g
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Rotation Speed
- 600/1000 rpm
- Air Flow
- 21.1/46.3 cmf
- Noise Level
- 8.9/19.9 dBA
- Power Connector
- Power Consumption
- 0.7-1.4 W
- RoHS
- Limited warranty: - 2 years
