Antec TriCool 8cm Clear Case Fan 3 Speed 3-pin with 4-pin Adaptor
Quicklinx: 9PJXWS00 Mfr#: 0-761345-75080-6
Antec TriCool 0761345-75080-6 balances necessary cooling with quietness.
Antec TriCool case fan
Case fan
Fan Diameter
80 mm
Fan Height
25.4 mm
Rotation Speed
1500/2000/2600 rpm
Air Flow
20/26/34 cfm
Power Connector
3-pin plug, 4 pin Molex connector
Variable fan speed
8 cm x 8 cm x 2.54 cm
Fan speed monitoring
Case fan
8 cm
8 cm
2.54 cm
Heatsink & Fan
Fan Diameter
80 mm
Fan Height
25.4 mm
Rotation Speed
1500/2000/2600 rpm
Air Flow
20/26/34 cfm
Power Connector
Variable fan speed
RoHS
Sound Emission
18 dBA
