Antec TriCool 12cm Clear Case Fan 3 Speed 3-pin with 4-pin Adaptor
Quicklinx: 9PJZWS00 Mfr#: 0-761345-75120-9
Antec TriCool 0761345-75120-9 balances necessary cooling with quietness.
Antec TriCool 120mm - case fan
Case fan
Fan Diameter
120 mm
Fan Height
25.4 mm
Rotation Speed
1200/1600/2000 rpm
Power Connector
3-pin plug, 4 pin Molex connector
Rated Voltage
12 V
Variable fan speed
Fan speed monitoring
Case fan
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25.4 mm
Rotation Speed
1200/1600/2000 rpm
Noise & Performance Details
25 dBA / 39 cfm at 1200 rpm , 28 dBA / 56 cfm at 1600 rpm , 30 dBA / 79 cfm at 2000 rpm
Power Connector
Rated Voltage
12 V
Variable fan speed
RoHS
