The full tower S10 is the flagship case of the Signature series by Antec, a family of chassis characterized by a patent pending internal architecture featuring an innovative Central Air Intake System and easy expandability with a striking, yet refined, exterior design. The exclusive three chamber design separates the enclosure into three thermal zones, providing clear airflow paths and efficient cooling to all of your components quietly. Seven pre-installed fans plus one optional fan mount combine with support for top, center, and rear radiators to showcase the ample cooling options available in the S10. Ten PCI-E slots and fourteen (6 HDD, 8 SSD) tool-less drive bays make building a high-performance system a simple process. Finished with a smooth front bezel and opposing brushed aluminum doors, the S10 provides performance, security, and style for any computer system.
Three chamber system
Isolating the enclosure into three distinct chambers allows maximum airflow with minimal fan noise. -
Optimized cooling
Designed for high-performance system builds, the S10 features seven fans and support for 240/280 mm top, 240/280/360 mm central, and 120 mm rear-mounted radiators. -
High performance
Quad-SLI ready plus 10 PCI-E slots for up to four 13.5" PCI-E graphics cards. -
Hassle-free maintenance
Quick-release washable air filters slide out effortlessly and dedicated filters for each chamber make managing a dust-free system quick and simple.
- Antec Signature Series S10 - tower - extended ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Black with brushed aluminum doors
- I/O Connectors
- 4 x USB 3.0 , 1 x headphones/speakers , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX, Extended ATX, XL-ATX
- System Cabinet Features
- Supports 120 mm radiator in rear, supports 240/280 mm radiator in top, supports 240/280/360 mm radiator in centre
- Power Device
- No power supply
- 23 cm x 59 cm x 60.2 cm
- 20.42 kg
- 3-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- Extended ATX
- Internal Bays Qty
- 14
- Cooling System
- Top: 140 mm fan x 2 / exhaust , 120 mm fan x 3 / intake , Rear: 120 mm fan x 1 / exhaust , 120 mm fan x 1 / exhaust , 120 mm fan mount x 1 / intake
- CPU Cooler Max Height
- 165 mm
- Video Card Max Length
- 343 mm
- Expansion Bays
- 6 (total) / 6 (free) x internal - 3.5" , 8 (total) / 8 (free) x internal - 2.5"
- Expansion Slots
- 10
- 4 x USB 3.0 , 1 x headphones/speakers - mini-jack , 1 x microphone - mini-jack
- RoHS
- Power Device
- No power supply
- 23 cm
- 59 cm
- 60.2 cm
- 20.42 kg
- Limited warranty - 3 years
