Your basket is empty
Antec PRO 80mm Fan
Antec PRO 80mm Fan
Customer rating: 4.0* (Write a review)
Quicklinx: 3467WS00 Mfr#: 0761345-75000-4
Type: Case Fan
Stock Status: Clearance
Hurry, only 2 left in stock!
£2.25 ex VAT
£2.70 inc VAT
Express delivery Delivered on Tuesday
Case fans help protect your whole computer investment by providing case cooling to reduce component-killing heat buildup, thus increasing the longevity of components.
Antec PRO DBB - case fan
Case fan
Fan Diameter
80 mm
Fan Height
25.4 mm
Fan Bearing
One sleeve & two ball bearing
Rotation Speed
2600 rpm
Air Flow
34 cfm
Power Connector
3-pin plug, 4 pin Molex connector
8 cm x 8 cm x 2.54 cm
70 g
Fan speed monitoring
Case fan
8 cm
8 cm
2.54 cm
70 g
Heatsink & Fan
Fan Diameter
80 mm
Fan Height
25.4 mm
Fan Bearing
Rotation Speed
2600 rpm
Air Flow
34 cfm
Power Connector
RoHS
Sound Emission
30 dBA
Antec PRO 80mm Fan                  Bundle deal on Antec PRO 80mm Fan
£15.74
saving £7.27
Customer reviews
Write a review for the Antec PRO 80mm Fan here!
Good stuff.
Reviewed by Anonymous Review Posted 15/01/2008
Excellent fan - use them all the time around the college and is a regular order.
Comes with all screws and wires you need.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Very Disappointed
Reviewed by Chris. Review Posted 11/10/2007
These fans are VERY loud, i have 2 other LED 80mm fans that cost about £1.30 each or something and they are quieter than these Antec ones. In fact i have two 50p (yes 50 PENCE) black generic 80mm fans that i got the Antec ones to replace and even they are quieter than these things. I am really quite annoyed i paid nearly £7 for these two fans and i have to use my Zalman FanMate to run them at half speed (11R00PM or thereabouts), i had to jerryrig the two fan connectors to do it, but it seems to work fairly well, but now i don't have anything to control my Zalman 9500 (except Q Fan which sucks). Bottom line, VERY loud and NOT good value.
  • Overall 2*
  • Ease of use 4*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Type: Case Fan
Brand: Antec
Price Range Ex VAT: 0 - 50
