Product
Brand
Antec PRO 80mm DBB Clear Double Ball Bearing Case Fan
Quicklinx: 737YWS00 Mfr#: 0761345-75001-1
Case fans help protect your whole computer investment by providing case cooling to reduce component-killing heat buildup, thus increasing the longevity of components.
Antec PRO case fan
Case fan
Fan Diameter
80 mm
Fan Height
25.4 mm
Fan Bearing
Dual ball bearing
Rotation Speed
2600 rpm
Air Flow
34 cfm
Power Connector
3-pin plug, 4 pin Molex connector
8 cm x 8 cm x 2.54 cm
70 g
Fan speed monitoring
Case fan
8 cm
8 cm
2.54 cm
70 g
Heatsink & Fan
Fan Diameter
80 mm
Fan Height
25.4 mm
Fan Bearing
Dual ball bearing
Rotation Speed
2600 rpm
Air Flow
34 cfm
Power Connector
RoHS
Sound Emission
30 dBA
