The P100 is an ATX case that epitomizes cool, quiet, and sophistication. It features the Performance One series design and Quiet Computing technologies that minimize system noise. In addition to 7 expansion slots, the P100 also supports 2 tool-less 5.25" drives and 7 tool-less 3.5"/2.5" drives. A balance of price and feature is achieved by integrating Antec design with superior build quality. Engineered with Quiet Computing technology, the P100 is truly in a class all its own.
- Antec Performance One P100 - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- I/O Connectors
- 2 x USB 3.0 , 2 x USB 2.0 , 1 x audio line-out/headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Water cooling holes
- Power Device
- No power supply
- 22 cm x 52.3 cm x 48.4 cm
- 3-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 7
- Front Accessible Bays Qty
- 2
- Cooling System
- Front: 120 mm fan x 1 , Rear: 120 mm fan x 1 , Front: 120/140 mm fan mount x 2 , Top: 120/140 mm fan mount x 1
- CPU Cooler Max Height
- 170 mm
- Video Card Max Length
- 317.5 mm
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" x 1/2H , 7 (total) / 7 (free) x internal - 2.5" / 3.5" shared
- Expansion Slots
- 7
- 2 x USB 3.0 , 2 x USB 2.0 , 1 x audio line-out/headphones - mini-jack , 1 x microphone - mini-jack
- RoHS
- Power Device
- No power supply
- 22 cm
- 52.3 cm
- 48.4 cm
- Limited warranty - 3 years
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
