For builders and seasonal system integrators alike, everyone will find something to like in Antec's One. This enclosure is stocked with features any builder will value at an attractive price - ample cooling, USB 3.0, tool-less 5.25" and 3.5" drive bays and bottom-mounted PSU intake with air filter - so that you can put your PC together with ease and get to the fun stuff. If you're looking for high quality PC essentials at an affordable cost, then this enclosure is the One for you.
- Front I/O ports: 2 x USB 3.0 with included USB 2.0 adapter / Audio In/Out
- Tool-less 3.5"e; drive bays
- Maximum graphics card length: 10.5"e; (266 mm)
- 1 x 120 mm rear exhaust fan
- 7 expansion slots
- Tool-less 5.25"e; drive bays
- Maximum size CPU cutout
- 1 x 120 mm top exhaust fan
- Antec One - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- I/O Connectors
- 2 x USB 3.0 , 1 x microphone , 1 x audio line-out/headphones
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Air filter, water cooling holes
- Power Device
- No power supply (ATX)
- 20.8 cm x 48.8 cm x 43.8 cm
- 4.9 kg
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 7
- Front Accessible Bays Qty
- 3
- Cooling System
- Top: 120 mm fan x 1 / exhaust , Rear: 120 mm fan x 1 / exhaust , Side: 120 mm fan mount x 1 / intake , Front: 120 mm fan mount x 1 / intake , Bottom: 120 mm fan mount x 1 / 1 x 140 mm fan supported
- Expansion Bays
- 3 (total) / 3 (free) x front accessible - 5.25" x 1/2H , 5 (total) / 5 (free) x internal - 3.5" x 1/3H , 2 (total) / 2 (free) x internal - 2.5"
- Expansion Slots
- 7 x Expansion Slot
- 2 x USB 3.0 , 1 x microphone - mini-jack , 1 x audio line-out/headphones - mini-jack
- Included Accessories
- USB 2.0 adapter
- Power Device
- No power supply
- Specification Compliance
- ATX
- Max Supported Qty
- 1
- 20.8 cm
- 48.8 cm
- 43.8 cm
- 4.9 kg
