Your basket is empty
Antec NSK4100 ATX Case No PSU Front USB 3.0 & Audio Matte Black
Quicklinx: 9PLXWS00 Mfr#: 0-761345-94480-9
Case Form Factor: Mid tower
Motherboard Form Factor: ATX
Power Supply: [N/A]
Colour: Matte black
£30.50 ex VAT
£36.60 inc VAT
The NSK4100 was designed to compliment any environment with its matte exterior and sleek front bezel with indirect intake vents. In addition to its striking appearance, the NSK4 100 is constructed of 0.6 SECC steel achieves an excellent price to value ratio by integratig Antec's proprietary Quiet Computing technology with solid build quality and superior expandability. The NSK series 4100 case supports standard ATX, Micro ATX and mini ITX motherboards and has ample space for full length graphics cards. It is capable of supporting liquid CPU cooling. three 5.25" drives, six 3.5" HDDs, and one 2.5" SSD. It contains two fan mounting points with room for seven expansion slots.
Antec New Solution NSK4100 - mid tower - ATX
System cabinet
Mid tower
Matte black
I/O Connectors
2 x USB 3.0 , 1 x audio line-out/headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Liquid cooling holes
No power supply
18.5 cm x 47.85 cm x 40.8 cm
5.2 kg
3 years warranty
Mid tower
Max Mainboard Size
ATX
Internal Bays Qty
7
Front Accessible Bays Qty
4
Matte black
Cooling System
Rear: 120 mm fan x 1 , Front: 80/90/120 mm fan mount x 1 , Side: 120 mm fan mount x 1
Video Card Max Length
280 mm
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" x 1/2H , 1 (total) / 1 (free) x front accessible - 3.5" , 6 (total) / 6 (free) x internal - 3.5" , 1 (total) / 1 (free) x internal - 2.5"
Expansion Slots
7
2 x USB 3.0 , 1 x audio line-out/headphones - mini-jack , 1 x microphone - mini-jack
RoHS
No power supply
18.5 cm
47.85 cm
40.8 cm
5.2 kg
Limited warranty - 3 years
Antec NSK4100 ATX Case No PSU Front USB 3.0 & Audio Matte Black Bundle deal on Antec NSK4100 ATX Case No PSU Front USB 3.0 & Audio Matte Black
£51.69
saving £14.13
9PLX C2G 4 port USB 3.0 SuperSpeed Hub In Stock £60.79
9PLX C2G 2m USB 3.0 A Male to Micro B Male Cable In Stock £5.89
Power Supply: [N/A]
Colour: Matte black
Brand: Antec
Price Range Ex VAT: 0 - 50
