Quiet, understated and very practical, the NSK3480 microATX Tower maintains the innovative standards of Antec's new Solution Series enclosures. Including an 80PLUS Certified EarthWatts 380W ATX12V v2.2 power supply with universal input and active PFC, the NSK3480 also utilizes Quiet Computing technologies, making it an ideal choice for corporate or home environments. The NSK3480: small, quiet and highly efficient.
- Antec New Solution NSK3480-UK - tower - micro ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Localisation
- United Kingdom
- I/O Connectors
- 2 x USB 2.0 , 1 x FireWire , 1 x headphones , 1 x microphone
- Installed Fans Qty
- 1
- Supported Motherboards
- microATX
- System Cabinet Features
- Vibration-absorbing drive cage
- Power Device
- Power supply 380 Watt (ATX12V 2.2)
- 20 cm x 36 cm x 35 cm
- 8.1 kg
- 3-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- Micro ATX
- microATX
- Internal Bays Qty
- 1
- Front Accessible Bays Qty
- 3
- Fans
- Rear: 1 x 12 cm - (1 installed) , Front: 2 x 9.2 cm - (0 installed)
- Localisation
- United Kingdom
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" x 1/2H , 1 (total) / 1 (free) x front accessible - 3.5" x 1/3H , 1 (total) / 1 (free) x internal - 3.5" x 1/3H
- Expansion Slots
- 4 x Expansion Slot
- 2 x USB 2.0 , 1 x FireWire , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- RoHS
- Power Device
- Power supply
- Specification Compliance
- ATX12V 2.2
- Installed Qty
- 1
- Max Supported Qty
- 1
- Power Provided
- 380 Watt
- Power Supply Features
- Active Power Factor Correction (PFC)
- 80 PLUS Certification
- 80 PLUS
- 20 cm
- 36 cm
- 35 cm
- 8.1 kg
- Limited warranty - 3 years
