Going small shouldn't mean sacrificing form or function. The ISK 110 VESA is crafted for small, efficient builds without compromises. Just 78 mm wide and mounted on a stable clip-on base or included VESA mount, it fits two 2.5" drive bays - perfect for internal SSDs. Perforated mesh construction and space for a low-profile CPU cooler provide an ample amount of quiet cooling capability. Ideal for corporate builds, kiosks and digital signage, the ISK 110 VESA is a miniscule case solution with massive features.
- Antec ISK110 VESA - SFF - mini ITX
- Product Type
- System cabinet
- Form Factor
- Small form factor
- Black, silver
- Localisation
- English
- I/O Connectors
- 4 x USB 2.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- Mini-ITX
- System Cabinet Features
- VESA mounting interface
- Power Device
- Power adapter 90 Watt
- Voltage Required
- AC 120/230 V
- 8.5 cm x 21.2 cm x 22.6 cm
- 1.3 kg
- Form Factor
- Small form factor
- Max Mainboard Size
- Mini ITX
- Mini-ITX
- Internal Bays Qty
- 2
- Black, silver
- Localisation
- English
- Expansion Bays
- 2 (total) / 2 (free) x internal - 2.5"
- 4 x USB 2.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- RoHS
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V
- Power Provided
- 90 Watt
- 8.5 cm
- 21.2 cm
- 22.6 cm
- 1.3 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
