Antec Minuet 350 Piano Black Slimline PC Case
ELEGANT MINI-DESKTOP CASE!
Quicklinx: 7378WS00 Mfr#: 0761345-08943-2
This elegant mini-desktop boasts impressive performance and a remarkably svelte profile, perfect for system builders looking for a smaller chassis. Its slender footprint and included bracket allow it to fit vertically or horizontally into the tightest spaces. With a reliable high efficiency 80PLUS certified 350 watt power supply and front USB, eSATA and audio ports, the Minuet 350 delivers the ideal blend of performance and convenience.
Antec New Solution Minuet 350 -UK - SFF - micro ATX
System cabinet
Small form factor
Piano black
United Kingdom
I/O Connectors
2 x USB 2.0 , 1 x eSATA , 1 x headphones , 1 x microphone
Installed Fans Qty
1
Supported Motherboards
microATX
System Cabinet Features
Desktop to tower convertible, flip-up drive cage, fan speed controller
Power supply 350 Watt (ATX12V)
Motherboard Power Connectors
24(20) pin power connector with detachable 4 pin section, 4-pin ATX12V connector
31.9 cm x 43.9 cm x 9.4 cm
5.7 kg
3-year warranty
Small form factor
Max Mainboard Size
Micro ATX
microATX
Internal Bays Qty
1
Front Accessible Bays Qty
2
Piano black
Fans
Top: 1 x 8 cm - (1 installed)
United Kingdom
Expansion Bays
1 (total) / 1 (free) x front accessible - 5.25" , 1 (total) / 1 (free) x front accessible - 3.5" , 1 (total) / 1 (free) x internal - 3.5"
Expansion Slots
4 x Expansion Slot
2 x USB 2.0 , 1 x eSATA , 1 x headphones - mini-jack , 1 x microphone - mini-jack
Power supply
Specification Compliance
ATX12V
Installed Qty
1
Max Supported Qty
1
Power Provided
350 Watt
Power Supply Features
Active Power Factor Correction (PFC)
80 PLUS Certification
80 PLUS
31.9 cm
43.9 cm
9.4 cm
5.7 kg
Limited warranty - 3 years
