This elegant mini-desktop boasts impressive performance and a remarkably svelte profile, perfect for system builders looking for a smaller chassis. Its slender footprint and included bracket allow it to fit vertically or horizontally into the tightest spaces. With a reliable high efficiency 80PLUS certified 350 watt power supply and front USB, eSATA and audio ports, the Minuet 350 delivers the ideal blend of performance and convenience.
- Antec New Solution Minuet 350 -UK - SFF - micro ATX
- Product Type
- System cabinet
- Form Factor
- Small form factor
- Piano black
- Localisation
- United Kingdom
- I/O Connectors
- 2 x USB 2.0 , 1 x eSATA , 1 x headphones , 1 x microphone
- Installed Fans Qty
- 1
- Supported Motherboards
- microATX
- System Cabinet Features
- Desktop to tower convertible, flip-up drive cage, fan speed controller
- Power Device
- Power supply 350 Watt (ATX12V)
- Motherboard Power Connectors
- 24(20) pin power connector with detachable 4 pin section, 4-pin ATX12V connector
- 31.9 cm x 43.9 cm x 9.4 cm
- 5.7 kg
- 3-year warranty
- Form Factor
- Small form factor
- Max Mainboard Size
- Micro ATX
- microATX
- Internal Bays Qty
- 1
- Front Accessible Bays Qty
- 2
- Piano black
- Fans
- Top: 1 x 8 cm - (1 installed)
- Localisation
- United Kingdom
- Expansion Bays
- 1 (total) / 1 (free) x front accessible - 5.25" , 1 (total) / 1 (free) x front accessible - 3.5" , 1 (total) / 1 (free) x internal - 3.5"
- Expansion Slots
- 4 x Expansion Slot
- 2 x USB 2.0 , 1 x eSATA , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Power Device
- Power supply
- Specification Compliance
- ATX12V
- Installed Qty
- 1
- Max Supported Qty
- 1
- Power Provided
- 350 Watt
- Power Supply Features
- Active Power Factor Correction (PFC)
- 80 PLUS Certification
- 80 PLUS
- 31.9 cm
- 43.9 cm
- 9.4 cm
- 5.7 kg
- Limited warranty - 3 years
