Your basket is empty
Antec ISK600 Mini ITX Desktop Cube Case No PSU
Quicklinx: 9PLSWS00 Mfr#: 0-761345-15165-8
The ISK600 is a versatile enclosure that matches any CEO's desk, designer's office, or family living room. It is designed exclusively for Mini-ITX motherboards and barely takes up desk. In addition to 0.8 mm SECC steel, the ISK600 features elegantly designed brushed aluminum top and side panels. It will last for builds to come with space for a 12.5" graphics card. 2 expansion slots, and three drive bays.
Antec ISK600 - desktop slimline - mini ITX
System cabinet
Desktop slimline
I/O Connectors
1 x USB 2.0 , 1 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
Mini-ITX
No power supply
Specification Compliance
ATX
26 cm x 36.9 cm x 19.5 cm
3 years warranty
Desktop slimline
Max Mainboard Size
Mini ITX
Mini-ITX
ATX
Internal Bays Qty
5
Cooling System
Rear: 120 mm fan x 1
CPU Cooler Max Height
170 mm
Video Card Max Length
317.5 mm
Expansion Bays
3 (total) / 3 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
2
1 x USB 2.0 , 1 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
RoHS
No power supply
26 cm
36.9 cm
19.5 cm
Limited warranty - 3 years
9PLS C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
9PLS C2G 5m USB 2.0 A/B Cable - Black In Stock £4.24
9PLS C2G 2-Port USB 2.0 Manual Switch In Stock £16.25
9PLS C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.34
9PLS C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.75
9PLS C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.89
