Antec ISK 310-150 Mini-ITX Desktop
Quicklinx: 7370WS00 Mfr#: 0761345-08185-6
Mini-ITX is the next "big" thing. The ISK 310-150 is designed exclusively for Mini-ITX motherboards. With three drive bays, a quiet 80mm TriCool fan, and a 150-watt power supply, the ISK 310-150 can handle many of the tasks of a traditional PC, in a fraction of the space. Plus, its stylish, silver front bezel will fit in perfectly with your existing multimedia components. From petite desktop option to silent home theater, Antec's ISK 310-150 is an epic case of mini proportions.
Antec ISK310-150 - desktop slimline - mini ITX
System cabinet
Desktop slimline
Black, silver
United Kingdom
I/O Connectors
2 x USB 2.0 , 1 x eSATA , 1 x headphones , 1 x microphone
Installed Fans Qty
1
Supported Motherboards
Mini-ITX
System Cabinet Features
Manual fan speed control
Power adapter 150 Watt
22.2 cm x 32.8 cm x 9.6 cm
2.5 kg
3-year warranty
Desktop slimline
Max Mainboard Size
Mini ITX
Mini-ITX
Internal Bays Qty
2
Front Accessible Bays Qty
1
Black, silver
Fans
Side: 1 x 8 cm - (1 installed)
United Kingdom
Expansion Bays
1 (total) / 1 (free) x front accessible - 5.25" Slim Line , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
1 x Expansion Slot
2 x USB 2.0 , 1 x eSATA , 1 x headphones - mini-jack , 1 x microphone - mini-jack
RoHS
Power adapter
Installed Qty
1
Max Supported Qty
1
Power Provided
150 Watt
22.2 cm
32.8 cm
9.6 cm
2.5 kg
Limited warranty - 3 years
7370 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.63
7370 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.26
7370 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.83
