Antec ISK 300-150 Mini-ITX Desktop Case
Quicklinx: 76C6WS00 Mfr#: 0761345-08175-7
Mini-ITX is the next "big" thing. And now, Antec introduces the ISK 300-150, designed exclusively for Mini-ITX motherboards. With three drive bays, a quiet 80mm TriCool fan, and a stable 150-watt power supply, the ISK 300-150 can handle many of the tasks of a traditional PC, but in half the space. From petite desktop options to silent home theater, Antec's ISK 300-150 is an epic case of mini proportions.
Antec ISK300-150 - SFF - mini ITX
System cabinet
Small form factor
United Kingdom
I/O Connectors
2 x USB 2.0 , 1 x eSATA , 1 x headphones , 1 x microphone
Installed Fans Qty
1
Supported Motherboards
Mini-ITX
System Cabinet Features
Manual fan speed control
Power adapter 150 Watt
22.2 cm x 32.8 cm x 9.6 cm
2.5 kg
3-year warranty
Small form factor
Max Mainboard Size
Mini ITX
Mini-ITX
Internal Bays Qty
2
Front Accessible Bays Qty
1
Fans
Side: 1 x 8 cm - (1 installed)
United Kingdom
Expansion Bays
1 (total) / 1 (free) x front accessible - 5.25" Slim Line , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
1 x Expansion Slot
2 x USB 2.0 , 1 x eSATA , 1 x headphones - mini-jack , 1 x microphone - mini-jack
RoHS
Power adapter
Installed Qty
1
Max Supported Qty
1
Power Provided
150 Watt
22.2 cm
32.8 cm
9.6 cm
2.5 kg
Limited warranty - 3 years
Resources
The following resources are available for the Antec ISK 300-150 Mini-ITX Desktop Case
