Antec GX500 Gaming Case ATX No PSU USB 3.0 Tool-less Fan
Quicklinx: 9PLRWS00 Mfr#: 0-761345-15500-7
The GX 500 from Antec is built for demanding gamers. With an interior space that can accommodate graphic cards up to 380 mm long and 158 mm high CPU cooler it can integrate advanced efficient configurations.
The two controllers can be used to adjust the internal fans to always provide a good balance between performance and silence. USB 3.0 on the front, easy access to the side, front and top panels, tool-free mounting system, and extra wide feet for stability, everything is done to make the GX 500 one of the best gamer housings.
Antec GX500 - tower - ATX
System cabinet
Tower
Built-in Devices
Fan control panel
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
System Cabinet Features
Screwless drive bays, removable dust filter
No power supply
20.5 cm x 45.8 cm x 47.6 cm
4.5 kg
3-year warranty
Tower
Max Mainboard Size
ATX
Internal Bays Qty
5
Front Accessible Bays Qty
3
Built-in Devices
Fan control panel
Cooling System
Top: 120 mm fan x 2 , Rear: 120 mm fan x 1 , Front: 120 mm fan mount x 2 , Side: 120 mm fan mount x 1
CPU Cooler Max Height
158 mm
Video Card Max Length
380 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 1 (total) / 1 (free) x front accessible - 3.5" , 4 (total) / 4 (free) x internal - 3.5" , 1 (total) / 1 (free) x internal - 2.5"
Expansion Slots
7
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
RoHS
No power supply
20.5 cm
45.8 cm
47.6 cm
4.5 kg
Limited warranty - 3 years
