Your basket is empty
Antec Accent Lighting LED Red
Quicklinx: 8BY3WS00 Mfr#: 0-761345-77031-6
Show off your PC in a new light with the Antec Advance Accent Lighting USB-powered 6 LED strip. Easy to install and turn on, simply attach the LED strip onto the electronic device you desire, insert the USB plug into an available USB port or powered USB hub and then turn it on with its convenient on/off switch. Antec Advance Accent Lighting USB-powered 6 LED strip gives your components, desk, or even monitor a healthy glow today!
Antec Accent Lighting - system cabinet lighting (LED)
System cabinet lighting (LED)
Red
Length
37 cm
28 g
USB powered, on/off switch, 6 LED lights
1 year warranty
Length
37 cm
28 g
Red
RoHS
Limited warranty - 1 year
