Antec A40 Pro Quad Heatpipe CPU Air-Cooler
Quicklinx: CK37WS00 Mfr#: 0-761345-10923-9
Type: CPU Cooler
£17.78 ex VAT
£21.33 inc VAT
Antec A40 PRO. Suitable for: Processor, Type: Cooler, Fan diameter: 9.2 cm. Width: 100 mm, Depth: 75 mm, Height: 136 mm
  • Silent LED fan
    Whisper-quiet, 92mm blue LED PWM fan.
  • Four high performance heatpipes
    Straight Touch copper coated heatpipes provide full contact to the CPU, for more efficient heat transference.
  • Thermal conductive coating
    Aluminum oxide coating on the top fin boosts the efficiency of heat transfer and prevents oxidation.
  • Universal socket compatibility
    Compatibility with Intel and AMD platforms, and the push-pin mounting system and included thermal paste make for a fast, simple installation.
Antec A40 PRO processor cooler
Processor cooler
Package Content
Thermal paste
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA1151 Socket
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Fluid dynamic bearing
Rotation Speed
800-2200 rpm
Air Flow
38 cfm
Noise Level
16 - 23 dBA
Power Connector
4-pin fan connector
4 copper heatpipes, blue LED
10 cm x 13.6 cm x 7.5 cm
570 g
3-year warranty
Processor cooler
Package Content
Thermal paste
10 cm
13.6 cm
7.5 cm
570 g
Heatsink & Fan
Compatible With
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
800-2200 rpm
Air Flow
38 cfm
Noise Level
16 - 23 dBA
Power Connector
4-pin fan connector
Limited warranty - 3 years
Type: CPU Cooler
Brand: Antec
Price Range Ex VAT: 0 - 50
