Antec's high current power supply is the perfect PSU combination of power and efficiency. The High Current Gamer features a high-power +12 V rail and special heavy-duty high current connectors and cabling that supply extreme levels of power, and also superb efficiency thanks to 80 PLUS bronze certification and active PFC. If loads of power, high current engineering and extreme efficiency are what you're after, the High Current Gamer is the PSU for you.
- Antec High Current Gamer HCG-520M - power supply - 520 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.32/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Bronze
- 1.8 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Power Capacity
- 520 Watt
- Output Current
- +5V - 24 A , +3.3V - 24 A , +12V - 40 A , -12V - 0.8 A , +5VSB - 2.5 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 5 x 7 pin Serial ATA , 4 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- Cooling System
- 135 mm fan
- 15 cm x 16 cm x 8.6 cm
- 3-year warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Input Voltage Margin
- + 10% / - 10%
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Power Capacity
- 520 Watt
- Output Current
- Efficiency
- 87%
- 80 PLUS Bronze
- MTBF
- 100,000 hours
- Cooling System
- 135 mm fan
- Thermal monitoring, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection
- UL, TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, RoHS, GOST-R
- Limited warranty - parts and labour - 3 years
- 15 cm
- 16 cm
- 8.6 cm
- 1.8 kg
