The VP350 is crafted for just three things: quality, performance and incredible value. This entry-level solution gives you everything you need in a power supply. No twinkle lights or glittery paint jobs - just a 120 mm fan for effective and quiet cooling, dual +12 V rails for amazingly stable power, and heavy-duty protection circuitry for peace of mind, no matter how demanding your system. All the features, none of the waste: for builders that is strictly business, the VP350 is strictly power.
- Antec Basiq VP350P - power supply - 350 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3/ EPS12V 2.91
- 1.5 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 220-240 V
- Power Capacity
- 350 Watt
- Output Current
- +5V 18 A , +12V1 18 A , +12V2 18 A , -12V 0.3 A , +5VSB 2 A , +3.3V 20 A
- Cooling System
- 120 mm fan
- 15 cm x 14 cm x 8.6 cm
- 2-year warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 220-240 V
- Input Voltage Margin
- + 10% / - 10%
- Frequency Required
- 50 - 60 Hz
- Power Capacity
- 350 Watt
- Output Current
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, dual 12V rails, short-circuit protection
- TUV, C-Tick, GOST, CB, CCC, RoHS
- Limited warranty - parts and labour - 2 years
- 15 cm
- 14 cm
- 8.6 cm
- 1.5 kg
