Antec 300 Three Hundred Two Tower Case - with USB 3.0
Quicklinx: 7ZJGWS00 Mfr#: 0-761345-15320-1
Let the Games Begin
The team that brought you the Three Hundred is back with an enclosure designed to handle today and tomorrow's high-performance systems. Introducing the Three Hundred Two, the next standard in affordable gaming cases. Our newest chassis is built for gamers from the inside-out, from its aggressive front bezel, to its advanced cooling system. With tool-less 5.25" & 3.5" drive bays, a large cable management compartment and two front panel USB 3.0 ports with an internal connector, the Three Hundred Two is the rightful heir to the Gaming Series legacy
  • 11 drive bays: 3 x 5,25" tool-less drive bays / 2 x 2,5" drive bays (dedicated) / 6 x 3,5" tool-less drive bays
  • Motherboards: Standard ATX, microATX, Mini-ITX
  • 8 expansion slots
  • Maximum graphics card size: 318 mm (12,5")
  • Maximum CPU cooler height: 170 mm (6,7")
  • Cooling System: 1 x 120 mm rear TwoCool™ fan / 1 x 140 mm top TwoCool™ fan / 2 x 120 mm front intake fans (optional) / 1 x 120 mm side intake fan (optional) / 1 x 120 mm side exhaust fan behind motherboard (optional)
  • Perforated front bezel for maximum air intake
  • Water cooling support: top water cooling grommets
  • Enlarged CPU cutout
  • Front I/O ports: 2 x USB 3.0 with internal motherboard connector / Audio In/Out
  • No power supply included
  • Unit Dimensions: 513 mm (H) x 229 mm (W) x 471 mm (D) / 20,2" (H) x 9,0" (W) x 18,5" (D)
Antec Three Hundred Two - tower - ATX
System cabinet
Tower
I/O Connectors
2 x USB 3.0 , 1 x audio line-out , 1 x microphone
Supported Motherboards
System Cabinet Features
Meshed front panel, CPU cut-out, cable management holes
No power supply
Specification Compliance
ATX / PS/2
22.9 cm x 47.1 cm x 51.3 cm
6.9 kg
3-year warranty
Tower
Max Mainboard Size
ATX
ATX / PS/2
Internal Bays Qty
8
Front Accessible Bays Qty
3
Cooling System
Rear: 120 mm fan x 1 / TwoCool , Top: 140 mm fan x 1 / TwoCool , Front: 140 mm fan mount x 2 / intake , Side: 120 mm fan mount x 1 / intake , Side: 120 mm fan mount x 1 / exhaust
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" x 1/2H , 6 (total) / 6 (free) x internal - 3.5" x 1/3H , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
8 x Expansion Slot
2 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
RoHS
No power supply
Max Supported Qty
1
22.9 cm
47.1 cm
51.3 cm
6.9 kg
Limited warranty - 3 years
