Anker PowerCore III Wireless Power Bank
Quicklinx: GSR0WS00 Mfr#: A1617H11
Anker 533 Wireless Power Bank (PowerCore 10K)
The Freedom to Charge Anywhere
Wireless Charging. Anywhere.
The convenience of wireless charging is no longer confined to your home or office. Qi-certified charging up to 10W lets you fully charge an iPhone 11 in less than 4 hours no matter where you are.
Choose How You Charge
With wireless, USB, and USB-C charging all available, PowerCore gives you unprecedented choice over how you charge. You can even use all of them at once to charge 3 devices simultaneously.
High-Speed Charging
The 18W USB-C port offers the kind of charging speeds that you normally only find in a wall charger. Charge an iPhone 11 to 50% in 30 minutes or fully charge a Galaxy S20 in less than 2 hours.
Power a Full Day
PowerCore is equipped with a 10,000mAh cell capacity to keep your devices charged for at least a full day. Charge an iPhone 11 or Pixel 4 more than twice, or charge a Galaxy S20 over 1.5 times.
Universal Compatibility
Qi-certification offers flawless wireless charging with compatible devices, while our exclusive PowerIQ 3.0 technology ensures optimized charging to virtually any mobile device including phones, tablets, and more.
Built-In Phone Stand
Slide-out the built-in phone stand to watch videos while charging. Note: Only wired charging can be accessed while using the phone stand.
Rapid Recharge
Connect an 18W charger (not included) to the USB-C port to fully recharge the internal battery in just 4.5 hours.
Notes
  • This wireless charger does not feature MagSafe-style magnetic alignment, and therefore is not able to charge the iPhone 12 series magnetically.
  • The wireless charging feature does not work with the Apple Watch series or Samsung Watch series.
  • Do not use a 5W charger to charge your phone wirelessly and recharge PowerCore simultaneously. To charge simultaneously at full speed, it’s recommended to use a charger with at least an 18W output.
  • Phone cases thicker than 5 mm, magnetic attachments, metal attachments, stands, or credit cards will interfere with wireless charging.
  • Place your phone on the center of the wireless pad to ensure stable charging. If your phone does not show as charging, adjust the position of your phone.
  • Press the power button to activate wireless charging.
  • 10,000 mAh is the total of the nominal rated capacity of internal battery cells.
  • Portable wireless charging
    Qi-certified to provide up to 10W of wireless charging power to phones, earbuds, or other devices on the go.
  • Desktop mode
    Use PowerCore as a wireless pad by connecting to a power supply via the USB-C port. Charge your device wirelessly while giving PowerCore's internal battery a full recharge.
  • High-speed USB charging
    Connect to either the USB-C or USB-A port to give your phone or tablet a powerful charge.
Anker PowerCore III 10K Wireless wireless power bank - USB, 24 pin USB-C - 18 Watt
Wireless power bank
Tablet, mobile phone, wireless earphones
6.84 cm x 15.18 cm x 1.87 cm
243 g
Black fabric
Output Connector Type
Total 2: USB, 24 pin USB-C
Fast Charge Technology
Anker PowerIQ 3.0
Wireless Charging
Wireless Charging Standards
Qi
10000 mAh
Power Provided
18 Watt
Power Device Details
- 4 pin USB Type A - 18 W , - 24 pin USB-C - 18 W
Cables
USB-C to USB-C cable
18 months warranty
Wireless power bank
6.84 cm
15.18 cm
1.87 cm
243 g
Enclosure Colour
Black fabric
Input Connectors
24 pin USB-C
Input Connectors Qty
1
Output connectors
Total 2: 4 pin USB Type A, 24 pin USB-C
Power Provided
18 Watt
4 pin USB Type A - 18 W , 24 pin USB-C - 18 W
Wireless Charging
Qi
Anker PowerIQ 3.0
10W wireless output, LED indicator, simultaneously charges up to 3 devices
10000 mAh
Recharge Time
4.5 hour(s)
Travel bag
Shipping Width
13 cm
Shipping Depth
20 cm
Shipping Height
3.5 cm
Shipping Weight
390 g
Limited warranty - 18 months
