Home Security Indoor Camera, Human and Pet AI, Works with Voice Assistants, Motion Tracking, Night Vision, MicroSD Card Required, HomeBase Not Required. by Eufy
Relevant Recordings: The on-device AI determines whether a human or pet is present and only records when an event of interest occurs.
The Key is in the Detail: View every event in crisp 2K clarity (1080P while using HomeKit) so you see exactly what is happening inside your home (24/7 1080p recording).
Smart Integration: Connect your Indoor Cam to Apple HomeKit, the Google Assistant, or Amazon Alexa for complete control over your surveillance. (HomeKit available via update. When opening HomeKit, users must add the device in the eufy Security app and then complete the activation process.)
Follows the Action: When motion is detected the camera automatically tracks and follows the moving object. Pan the lens 360° horizontally or tilt it 96° vertically to get a clear view of the whole room.
Communicate From Your Camera: Speak in real-time to anyone who passes via the camera’s built-in two-way audio.
Know when you are needed
The built-in AI notifies you of excessive noise levels so you know when your little one needs some attention. -
Instant detection
As soon as motion is detected the camera will start recording and push a notification in case you want to see what is happening. -
Activity zones
Only receive the alerts which matter. Customize the area in which detection takes place to suit your home. -
Sight at night
Keep an eye on any room, even in low light settings. -
Communicate from your camera
Speak in real-time to anyone who passes via the camera's built-in two-way audio. -
Instant mobile alerts
Notifies you in seconds when suspicious motions are detected. -
Dual storage options
Store your data and recordings locally or in the cloud. -
Follows the action
- Eufy Cam 2K Pan and Tilt - network surveillance camera
- Network surveillance camera - pan / tilt - indoor
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- 7.5 cm x 7.5 cm x 10.8 cm
- 217 g
- White
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/2.7"
- Panning Range (degree)
- 360
- Tilting Range (degree)
- 96
- Wi-Fi
- Platform
- Apple HomeKit
- Intelligent Assistant
- Google Assistant, Alexa
- Cables Included
- 1 - USB cable - external - 2 m
- Voltage
- DC 5 V
- Wide Dynamic Range (WDR), Pet Detection, NAS-Ready, auto tracking, audible alerts, cloud recording, zone analysing, human detection, instant notification, 125° field of view
- 1-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C; 0 - 90% relative humidity
- Audio Support
- Wireless
- 7.5 cm
- 7.5 cm
- 10.8 cm
- 217 g
Camera
- Colour - Day&Night - pan / tilt - indoor
- Digital Video Format
- H.264, H.265
- Motion Detection
- Video Modes
- 1080p
- Digital Zoom
- 8
- Infrared LEDs
- 8
- Infrared Distance
- 10 m
Image Sensor
- CMOS 1/2.7"
Panning
- Range (degree)
- 360
Tilting
- Range (degree)
- 96
- Network Interface
- Wi-Fi
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Included Accessories
- Mounting bracket, screws
- Cables Included
- 1 x USB cable - external - 2 m
- White
- Power Requirements
- DC 5 V - 2 A
- Power Device
- Power adapter - external
- OS Required
- Android 5.0 or later, Apple iOS 10.2 or later
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- Apple HomeKit
- Supported Host Device Platform
- iOS, Android
- Limited warranty - 1 year
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 0 - 90%
