Anker Eufy Add on Doorbell Chime for HB2
Quicklinx: G73LWS00 Mfr#: E8741021
Type: Doorbell
Compatible With: Alexa, Google Assistant
More than 50 in stock
£29.16 ex VAT
£34.99 inc VAT
Marketing description is not available.
  • Crystal-clear 2K image
    High-definition 2560 x 1920 resolution, combined with the advanced HDR and Distortion Correction, ensures video is recorded in 2x the quality.
  • No hidden costs
    Designed to protect your home as well as your wallet, eufy security products are one-time purchases that combine security with convenience.
  • Respond in real time
    Speak directly to anyone who approaches your front door via two-way audio. Tell your friends to come round the back or that you have just run out to get some milk.
  • Alerts which matter
    With AI technology and the sophisticated algorithm, the camera intelligently detects body shape and face pattern, ensuring you are only alerted when a human, and not a stray cat, is at the door.
  • Smart detection zones
    Activity Zone allows you to customize the areas in which the camera will detect motion. Set the Activity Zone to suit your home so you only receive the alerts you care about.
  • See the whole picture
    View 3 seconds of footage prior to the initial alert. Gain a clearer picture of what happened, and increase the likelihood of criminal identification.
  • Interaction made easy
    Record and set up to 3 instant responses. When you are notified of activity, simply select one of your pre-recorded responses to interact and give instructions.
Eufy - Add-on - doorbell
Doorbell
Functions
Motion detection, camera
Power Source
Intelligent Assistant
Google Assistant, Alexa
Max Supported Devices
4
Wireless - Wi-Fi
Frequency Band
2.4 Ghz
Camera
Max Resolution 2560 x 1920 - audio
1-year warranty
5.3 cm x 2.79 cm x 14 cm
Doorbell
Functions
Power Source
4
Wireless - Wi-Fi
Frequency Band
2.4 Ghz
Two-way audio support, 2K resolution support
Internet of Things (IoT)
Camera
Audio Support
Max Digital Video Resolution
2560 x 1920
Video Modes
2K
Built-in speaker, auto power save, Wide Dynamic Range (WDR), face detection, built-in microphone, 2-way voice communication, zone analysing, human detection, motion detection
Flash Memory
Installed Size
16 GB
Rechargeable Battery
Rechargeable
Battery Lifetime
180 days
Mounting bracket
Encryption Algorithm
256-bit AES
Warranty
1-year warranty
AES-256
5.3 cm
2.79 cm
14 cm
-20 °C
50 °C
Type: Doorbell
Brand: Anker
Stock Status: In stock
