AMD Ryzen Threadripper 1920X 12-Core 4.0GHz 38MB Cache 180W PIB
Quicklinx: D1WNWS00 Mfr#: YD192XA8AEWOF
Socket: Socket TR4
Type: Ryzen ThreadRipper
Clock Speed: 3.5GHz
15 in stock
£331.34 ex VAT
£397.60 inc VAT
Compose music. Orchestrate Fleets.
Conquer design and gaming with Ryzen™ Threadripper™.
Mega-task faster than ever before
Do everything. All at the same time.
Render. Stream. Compile. Encode. Work or Play. Threadripper has the power to overwhelm your most daunting workloads.
Unmatched processing power and a platform light years ahead
Threadripper is simply the fastest multi-threaded processor on a consumer desktop PC, ever.
Up to 16 cores provide an astonishing 32 threads of simultaneous multi-processing power, while up to 40MB of combined cache and vast I/O from the enthusiast-grade AMD X399 chipset stand ready to feed the beast.
AMD Ryzen Master
Your tool to unlock AMD Ryzen™ Processors
Every AMD Ryzen processor is multiplier-unlocked from the factory, so you can personalize performance to your taste. AMD provides the AMD Ryzen Master utility to access this powerful advantage.
AMD SenseMI Technology. Technology that thinks.
AMD introduces SenseMI technology, a set of learning and adapting features that help the AMD Ryzen™ processor customize its performance to you and your applications. Finally: performance that thinks.
Pure Power:
Cool and quiet processor operation using a sophisticated grid of smart sensors.
- Monitors CPU temperature, resource usage, and power draw
- Adaptive control optimizes power draw for any workload
- Minimized power consumption reduces system heat and noise
Precision Boost:
Fine-tuned processor performance adjusted in real time to meet the performance demands of your game or app.
- Adjusts clockspeeds in 25MHz increments to optimize performance
- Clockspeed changes can occur without pausing work
- High precision tuning with 25MHz increments
The "Zen" Core Architecture
Maximum Compute Efficiency
The "Zen" core is an all-new "clean sheet" x86 processor design that’s inspiring a new generation of high-performance AMD computing products in 2017 and beyond. "Zen" combines the latest thinking in high-throughput and low-power design methodologies to create a balanced and versatile architecture right at home in the desktop, laptop, datacenter and supercomputer.
  • AMD Ryzen Master Utility
    Unlock ultimate control over your AMD Ryzen powered system for personalized overclocking and efficiency.
  • Unmatched processing power and a platform light years ahead
    Multiple cores provide astonishing threads of simultaneous multi-processing power, while combined cache and vast I/O from the enthusiast-grade chipset stand ready to feed the beast.
AMD Ryzen ThreadRipper 1920X / 3.5 GHz processor
Processor Type
Number of Cores
12-core / 24 threads
Cache
32 MB
Compatible Processor Socket
Socket TR4
Processor Qty
1
Clock Speed
3.5 GHz
Max Turbo Speed
4 GHz
Manufacturing Process
14 nm
"Zen" Core Architecture, AMD SenseMI Technology, AMD Ryzen Master Utility, AMD Ryzen VR-Ready Premium
Type / Form Factor
Number of Cores
12-core
Number of Threads
24 threads
Cache
32 MB
Cache Memory Details
L3 - 32 MB , L2 - 6 MB , L1 - 1.125 MB
Processor Qty
1
Clock Speed
3.5 GHz
Max Turbo Speed
4 GHz
Socket TR4
14 nm
Thermal Design Power
180 W
Thermal Specification
68 °C
Architecture Features
Socket: Socket TR4
Clock Speed: 3.5GHz
Brand: AMD
Price Range Ex VAT: 300 - 500
