The AT-2911 series Gigabit Ethernet network adapters are integrated Ethernet network interface cards based on Broadcom's BCM5718 chipset with a PCI Express (PCIe) x 1 version 2 interface.
The AT-2911 series adapter connects a PCIe compliant computer to a Gigabit Ethernet network. Allied Telesis offers models equipped with a single port interface or dual port interface in the AT-2911 series.
The AT-2911 adapter is equipped with single or dual fiber optic connector, copper connector, SFP slot, or a combination of these connectors.
- Allied Telesis AT-2911LX/2LC - network adapter - PCIe 2.0 - 1000Base-LX x 2
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express 2.0 x1
- Ports
- 1000Base-LX x 2
- 8.25 cm x 6.89 cm
- 65.2 g
- Cabling Type
- Ethernet 1000Base-LX
- Data Link Protocol
- GigE
- Data Transfer Rate
- 1 Gbps
- TCP/IP
- IEEE 802.1Q, IEEE 802.3x, IEEE 802.3az
- Microsoft Certification
- Compatible with Windows 7
- Network adapter
- Form Factor
- Ports
- 1000Base-LX x 2
- Connectivity Technology
- Wired
- Cabling Type
- Gigabit Ethernet
- 1 Gbps
- TCP/IP
- Remote Management Protocol
- SNMP
- Status Indicators
- Link/activity
- Flow control, ACPI support, auto-negotiation, VLAN support, half duplex mode, full duplex mode, Jumbo Frames support, Energy Efficient Ethernet, PXE 2.0 support, checksum offload support
- 2 x 1000Base-LX - LC single-mode - x 2
- Included Accessories
- Full-height bracket
- MTBF
- 400,000 hour(s)
- C-Tick, EN 60950, ICES-003, EN55022 Class B, FCC Part 15 B, EN55024 Class B, RoHS, UL 60950-1, EN 60825, ACPI 1.1, VCCI Class B
- 8.25 cm
- 6.89 cm
- 65.2 g
- 0 °C
- 45 °C
- 5 - 90% (non-condensing)
