Your basket is empty
Allied Telesis AT GIGABIT ETHERNET FIBER ADAPTER CARD FIBRE LC CONNECTOR PC
Quicklinx: 9GPWWS00 Mfr#: AT-2931SX/LC-001
Allied Telesis' AT-2931SX is a high reliable 64-bit Gigabit Fiber Adapter card with 9KB Jumbo frames support for network upgrade needs. AT-2931SX helps to boost your Fast Ethernet server throughput ten times to 1000Mbps. With the 1000Base-SX fiber-optic connection, data transmission is both secure and faster.
In order to reduce CPU use, Allied Telesis' AT-2931SX uses the adaptive interrupts and ultra-deep 96-KB packet buffer. Coupled with link aggregation and load balancing, AT-2931SX achieves the best performance of its class for server connectivity.
Allied Telesis AT-2931SX/LC - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI 64 hot-plug 66 MHz
PCI Specification Revision
PCI 2.2
Ports
1000Base-SX
1.3 cm x 17.8 cm x 5.1 cm
85 g
Cabling Type
Ethernet 1000Base-SX
GigE
Max Transfer Distance
500 m
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1ad
Novell NetWare 5.x, Novell NetWare 6.x, Microsoft Windows 2000 / XP, Linux 2.4.x
Microsoft Certification
Works with Windows Vista
Network adapter
Plug-in card
PCI 2.2
Ports
1000Base-SX
Wired
Cabling Type
GigE
Data Transfer Rate
1 Gbps
500 m
TCP/IP, UDP/IP
Status Indicators
Link OK, link/activity
Flow control, auto-negotiation, load balancing, VLAN support, full duplex mode
1 x 1000Base-SX - LC multi-mode - x 2
Compatible Slots
1 x PCI 64 hot-plug 66 MHz
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
UL, VCCI, EN55022 Class B, FCC
1.3 cm
17.8 cm
5.1 cm
85 g
10 °C
55 °C
10 - 95%
