USB travel charger. For charging USB-powered devices from wall sockets. Works with most smart phones and portable music players.
Four easy-switch international plug types are included, this makes this charger the perfect travel companion.
- Single USB 5V DC port
- Easy switch four international plug types
- 110 - 220V full range input
- Akasa USB Travel Charger power adapter - USB
- Product Type
- Power adapter
- 2.5 cm x 2 cm x 4.2 cm
- 11.5 g
- Output Connector Type
- USB
- Voltage Required
- AC 110-240/ DC 12-24 mV
- Voltage Provided
- 5 V
- Product Type
- Power adapter
- 2.5 cm
- 2 cm
- 4.2 cm
- 11.5 g
- Voltage Required
- Voltage Provided
- 5 V
- Output connectors
- 4 pin USB Type A
