Product
Brand
Akasa USB 3.0 Type A Cable Extension 1.5m
Quicklinx: 72PZWS00 Mfr#: AK-CBUB02-15BK
*USB 3.0 cable extension: 150cm cable with type A male to female connectors *
150cm USB 3.0 cable extension. Type A male to type A female connectors. Super Speed 5Gbps bi-directional data transfer supported. Double shielded insulation and black sleeve. Can be used to connect USB devices such as printer, mice, keyboard, web cam, external HDD, card reader or USB hub which are located further away from the PC and need a longer cable connection.
  • Super Speed USB 3.0 cable extension
  • Data transfer up to 5Gbps
  • Bi-directional data interface
  • Double shielded insulation
  • USB 2.0 backwards
Spec
  • Application USB cable extension
  • Length 150cm
  • Connectors USB 3.0 Type-A male to female
  • Colour Black
Application
USB Cable Extension
Length
150cm
Connectors
USB 3.0 Type-A Male to Female
