Your basket is empty
Akasa Thermal Gap Filler interface pad - 5mm
Quicklinx: 97DLWS00 Mfr#: AK-TT300-02
Akasa thermal gap filler is a thermally conductive interface pad which is versatile and suitable for use between components and their heat sinks. The pad molds around uneven surfaces and can be cut to size to effectively solve and manage unwanted thermal issues.
Akasa AK TT300-02 - thermal pad
Thermal pad
Packaged Quantity
2 (specifications are for single item)
Product Material
Silicone elastomer
3 cm x 3 cm
Stackable
Packaged Quantity
Thermal pad
Product Material
Silicone elastomer
3 cm
3 cm
Thickness
0.5 cm
Stackable
-40 °C
160 °C
