Your basket is empty
Akasa Smart PWM Cable for 3 PWM Case Fans & Coolers, SATA
Quicklinx: 86XHWS00 Mfr#: AK-CBFA06-30
Smart connection of three fans from single motherboard PWM header, enables quiet operation of performance systems, length: 30cm
  • Supports 3 PWM fans from a single motherboard PWM header
  • Black braided cable
Specification
  • Application 3 PWM fans from single PWM header
  • Designed for 4pin PWM fans
  • Cable length 30cm
  • PSU connector SATA power
  • Fan connector 3 x 4pin PWM (one with RPM feedback for motherboard)
Akasa FLEXA FP3S - fan power adapter - 30 cm
Fan power adapter
Braided
Length
30 cm
Connectors
3 x 4 pin PWM - male
Connectors (Second End)
4 pin PWM - female , 15 pin Serial ATA power
Fan power adapter
Braided
Length
30 cm
Connectors
