- PWM function.
- Precision balanced low air impedance fan blades.
- Suitable for HTPC and slim system.
- Akasa Slimfan AK-FN076 - case fan
- Product Type
- Case fan
- Fan Diameter
- 80 mm
- Fan Height
- 10.8 mm
- Fan Bearing
- Entering bearing
- Air Flow
- 26.5 cfm
- Noise Level
- 25.1 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support
- 8 cm x 8 cm x 1.08 cm
- Product Type
- Case fan
- 8 cm
- 8 cm
- 1.08 cm
Heatsink & Fan
- Fan Diameter
- 80 mm
- Fan Height
- 10.8 mm
- Fan Bearing
- Entering bearing
- Air Flow
- 26.5 cfm
- Air Pressure
- 1.81 mm
- Noise Level
- 25.1 dBA
- Power Connector
- Rated Voltage
- 12 V
- Mounting Kit
- Included
