The eSATA adapter extends motherboard's capabilities by adding external eSATA connector. The external eSATA port located at the back I/O provides smart setup and enables ultra fast (up to 3Gb/s) data connection with external eSATA devices.
- Akasa SATA internal to external panel - 45 cm
- SATA internal to external panel
- Interface Speed
- Serial ATA 150/300
- Latched
- Length
- 45 cm
- Connector
- 7 pin Serial ATA - female
- Connector (Second End)
- 7 pin external Serial ATA - male
- Storage Cable Type
- Interface Speed
- Latched
- Length
- 45 cm
- Connector
