Akasa S478 3.4GHz Lo-Noise Fan
Customer rating: 1.0* (Write a review)
Quicklinx: 3VS4WS00 Mfr#: AK-675B
AK-675 is a low-noise and high performance value cooler. AK-450 hi-performance thermal compound is pre-applied. New production technology has produced this high performance cost effective cooler.
Akasa AK 675 - processor cooler
Processor cooler
Compatibility
Socket 478
Fan Diameter
80 mm
Fan Height
25 mm
Rotation Speed
2400 rpm
Air Flow
38.4 cfm
Noise Level
26 dBA
Processor cooler
Heatsink & Fan
Compatible With
Socket 478
Processor Compatibility
Pentium 4 - up to 2.8 GHz
Heatsink Dimensions
83 mm x 80 mm x 50 mm
Fan Diameter
80 mm
Fan Height
25 mm
Rotation Speed
2400 rpm
Air Flow
38.4 cfm
Noise Level
26 dBA
Customer reviews
Write a review for the Akasa S478 3.4GHz Lo-Noise Fan here!
Not that Lo-Noise
Reviewed by Anonymous Review Posted 28/03/2007
If you want a quieter pc then look elseware.. This cooler is not quiet at all, certainly not the stated 26db.. I gave it a try because it had an 80mm fan which meant that it probably would be quiet but the fan spins at 3300rpm so its actually quite loud.. I amd going to try an alternate fan because the heatsink itself looks quite good and its holding my CPU at about 39deg.. Of course the quieter fan may not provide enough airflow to ceep the cpu cool.. If you want a cheap cooler this one is for you, if you want a quiet one keep looking..
  • Overall 1*
  • Ease of use 3*
  • Value for money 3*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
