Product
Brand
Akasa Quasar Large Mesh Ergonomic Cooling Stand 15.6"-17"
Price Drop!
Clearance
Price Drop
Last Few Remaining
Quicklinx: 7H5GWS00 Mfr#: AK-NBC-32
Quasar: Widescreen notebook cooler
20cm fan delivers ultra-cooling performance, ergonomic design provides comfortable keyboard operation.
  • Powered directly from your notebook
  • Strong, stylish ventilated body enhances heat dissipation
  • Adjustable fan speed for quiet or performance
  • Suitable for 17" widescreen or below
Specification
  • Application 17" - 15.6" Notebooks / MacBooks
  • Material ABS structure with mesh face panel
  • Outline dimension 380 x 322 x 50mm
  • Fan dimension 200 x 200 x 20mm
  • Fan speed High speed 800 RPM, low speed 500 RPM
  • Fan air flow 63.7 CFM
  • Fan air pressure 0.44mm H2O
  • Voltage rating 5V DC
  • USB cable 600mm
  • Weight 710g
  • Available colours Black
Akasa AK NBC-32 Quasar - notebook fan
Notebook fan
Package Content
USB cable
Fan Diameter
200 mm
Fan Height
20 mm
Rotation Speed
500/800 rpm
Air Flow
63.7 cfm
Rated Voltage
5 V
38 cm x 32.2 cm x 5 cm
0.71 kg
Notebook Compatibility
17"
Mesh top panel
Notebook fan
Package Content
USB cable
38 cm
32.2 cm
5 cm
0.71 kg
17"
Heatsink & Fan
Fan Diameter
200 mm
Fan Height
20 mm
Rotation Speed
500/800 rpm
Air Flow
63.7 cfm
Air Pressure
0.44 mm
Rated Voltage
5 V
Mesh top panel
