- Aluminium fanless CPU cooling design
- Stylish front panel diamond effect
- Support one serial port
- Support IR remote function
Compatible with the following IntelĀ® NUC Board:
NUC5i5MYBE / NUC5i5MYHE / NUC5i3MYBE / NUC5i3MYHE NUC5i5RYH / NUC5i5RYK / NUC5i3RYH / NUC5i3RYK
- Akasa Newton s - USFF - UCFF
- Product Type
- System cabinet
- Form Factor
- Ultra small form factor
- I/O Connectors
- 2 x USB 3.0 , 1 x audio
- Supported Motherboards
- UCFF
- System Cabinet Features
- VESA mounting interface, Kensington lock support, aerial fitting holes
- Power Device
- No power supply
- 17.65 cm x 20 cm x 5.35 cm
- Form Factor
- Max Mainboard Size
- UCFF
- UCFF
- Product Material
- Aluminium
- Expansion Bays
- 1 (total) / 1 (free) x internal - 2.5"
- 2 x USB 3.0 , 1 x audio - mini-jack
- Included Accessories
- SATA cable, HDD protective film, 2.5" HDD mounting bracket, thermal paste, washer, screws, power cable, thermal module, case feet kit, serial cable, thermal gap filler x 3
- Power Device
- No power supply
- 17.65 cm
- 20 cm
- 5.35 cm
