mSATA to SATA adapter is used to connect 2.5" HDD / SSD to mini PCI Express slot with mSATA support. Compatible with IntelĀ® NUC board.
- Application mSATA to SATA adapter
- Designed for 2.5" HDD / SSD
- Input Voltage 19V
- Output Voltage 5V
- Power Consumption 10W
- Product code AK-PCCMSA-01
- Akasa AK-PCCMSA-01 - storage controller - SATA 3Gb/s - SATA 3Gb/s
- Storage controller - internal
- Bus Type
- SATA 3Gb/s
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 3Gb/s
- Supported Devices
- Hard drive, solid state drive
- 2.5"
- Host Bus
- SATA 3Gb/s
Storage Controller
- Interface
- SATA 3Gb/s
- Supported Devices
- 1 x SATA 3Gb/s - SATA combo
- Connections
- 1 x SATA 3Gb/s - 52 pin mini-SATA
- Cables Included
- 1 x Serial ATA cable - internal
