K25: Designed for mini-ITX and micro-ATX chassis
- Core 2 Duo, Core i3 & Core i5 processors
Ultra compact and low noise cooler for Intel Core 2 Duo, Core i3 and Core i5 (73W) CPU's. The low profile design with embedded S-Flow fan makes it a perfect solution for mini-ITX, HTPC and SFF systems.
Aluminium heatsink with full height copper core and quiet HDB bearing fan ensure high efficiency and long life. High engineered multi directional aluminium heatsink maximizes heat dissipation and PWM fan provides optimal CPU, motherboard and VRM cooling with minimal noise levels.
Intel approved pushpins ensure easy installation, reliable retention and maximum compatibility on both LGA775, LGA1155 and LGA1156 platforms without any mounting adjustment, pushpins will automatically slide into correct position. K25 is designed to work with CPU's up to 73W but greater cooling efficiency can be attained with efficient case airflow. Pre-applied high performance thermal compound ensures clean and easy installation.
- For Intel LGA775, LGA1155, LGA1156
- Embedded 8cm PWM fan with S-Flow blades and long life bearing
- Intel approved push pins provide maximum compatibility
- High performance thermal interface is pre-applied
- Socket type Intel LGA775 , LGA1155, LGA1156
- Cooler dimension 87.2 x 85.2 x 29.5 mm
- Heatsink material Aluminum with copper insert
- Weight 220 g
- Installation Push pins
- Fan dimension Ø74 x 15 mm
- Fan speed 600 - 3000 RPM (PWM controlled)
- Max airflow 33.50 CFM
- Max air pressure 3.76 mmH2O
- Noise level 28.71 dB(A)
- Voltage rating 12V DC
- Bearing type HDB
- Fan life expectancy 50,000 hours
- Fan connector 4pin PWM
- Akasa K25 AK-CC7118HP01 - processor cooler
- Product Type
- Processor cooler
- Compatibility
- LGA775 Socket, LGA1156 Socket, LGA1155 Socket
- Heatsink Material
- Aluminium with copper base
- Fan Diameter
- 74 mm
- Fan Height
- 15 mm
- Fan Bearing
- Hydrodynamic bearing
- Rotation Speed
- 600-3000 rpm
- Air Flow
- 33.5 cfm
- Noise Level
- 28.7 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support
- 8.7 cm x 8.5 cm x 3 cm
- 220 g
- Product Type
- Processor cooler
- 8.7 cm
- 8.5 cm
- 3 cm
- 220 g
Heatsink & Fan
- Compatible With
- Processor Compatibility
- Core 2 Duo , Core i3 , Core i5
- Heatsink Material
- Fan Diameter
- 74 mm
- Fan Height
- 15 mm
- Fan Bearing
- Rotation Speed
- 600-3000 rpm
- Air Flow
- 33.5 cfm
- Air Pressure
- 3.76 mm
- Noise Level
- 28.7 dBA
- Power Connector
- Rated Voltage
- 12 V
