Product
Brand
Akasa LGA775/1156 Ali Multi-Directional Push Pin Heatsink 92mm PWM
Quicklinx: 8206WS00 Mfr#: AK-CC7108EP01
AK-CC7108EP01 is an OEM CPU cooler combining low noise, efficient cooling with great value. High engineered omni directional aluminum heatsink with bi-ped fins maximize heat dissipation and provides optimal CPU and motherboard VRM cooling. Low noise 9.2 cm PWM fan uses Intel approved power management (PWM) where speed is regulated automatically by CPU usage. Under normal conditions the CPU fan speed is low ensuring low noise computing.
AK-CC7108EP01 is designed to work with CPU's up to 77 W but greater cooling efficiency can be attained with efficient case airflow. Pre-applied high performance thermal compound ensures clean and easy installation.
Akasa AK CC7108EP01 - processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, LGA1155 Socket
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Entering bearing
Rotation Speed
600-3000 rpm
Air Flow
56.8 cfm
Noise Level
17.2 - 30.54 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
9.5 cm x 9.5 cm x 5.85 cm
292.3 g
Processor cooler
9.5 cm
9.5 cm
5.85 cm
292.3 g
Heatsink & Fan
Compatible With
Processor Compatibility
Core 2 Duo - all speeds , Core i3 - all speeds , Core i5 - all speeds
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Height
25 mm
Fan Bearing
Entering bearing
Rotation Speed
600-3000 rpm
Air Flow
56.8 cfm
Air Pressure
4.05 mm
Noise Level
17.2 - 30.54 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.21 A
MTBF
40,000 hours
