K32 uses a high engineering omni directional heatsink providing efficient CPU and motherboard zone cooling. Low noise 9.2 cm PWM fan uses Intel approved power management (PWM) where speed is regulated automatically by CPU usage. Under normal conditions the CPU fan speed is low ensuring low noise computing.
K32 is designed to work with CPU's up to 95 W but greater cooling efficiency can be attained with efficient case airflow. Pre-applied high performance thermal compound ensures clean and easy installation.
- Akasa K32 AK-CC7117EP01 - processor cooler
- Product Type
- Processor cooler
- Compatibility
- LGA775 Socket, LGA1156 Socket, LGA1155 Socket
- Fan Diameter
- 92 mm
- Fan Height
- 25 mm
- Fan Bearing
- Entering bearing
- Rotation Speed
- 600-3000 rpm
- Air Flow
- 57 cfm
- Noise Level
- 17.2 - 30.54 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support
- 9.5 cm x 9.5 cm x 6.2 cm
- 326 g
- Product Type
- Processor cooler
- 9.5 cm
- 9.5 cm
- 6.2 cm
- 326 g
Heatsink & Fan
- Compatible With
- Processor Compatibility
- Pentium 4 , Core 2 Duo , Core 2 Quad , Core i3 , Core i5
- Fan Diameter
- 92 mm
- Fan Height
- 25 mm
- Fan Bearing
- Entering bearing
- Rotation Speed
- 600-3000 rpm
- Air Flow
- 57 cfm
- Air Pressure
- 4.1 mm
- Noise Level
- 17.2 - 30.54 dBA
- Power Connector
- Rated Voltage
- 12 V
