Your basket is empty
Akasa Internal USB 3.0 Multi Card Reader SD4.0 Supported
Quicklinx: BWFCWS00 Mfr#: AK-ICR-27
  • Supports SDHC / SDXC and new UHS-II standard
  • Four card-slots are active at the same time, allowing cross format data transfer
  • USB 3.0 data read and write
  • USB 3.0 port backwardly compatible with USB 2.0
Akasa card reader - USB 3.0
Card reader - internal
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick PRO Duo, CompactFlash Card, MultiMediaCardmobile, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, SDXC Memory Card, microSDXC, SDHC UHS-II Memory Card, SDXC UHS-II Memory Card
Host Interface
USB 3.0
Required Bay
3.5" internal
Built-in USB hub
Host Interface
USB 3.0
Required Bay
3.5" internal
Built-in USB hub
Additional Ports
1 x USB 3.0
Required Ports
1 x 20 pin USB 3.0 header
Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10
