Akasa Intel LGA775/1156 Lo Noise Ali Core HS w/ Embedded PWM 2Ball
Quicklinx: 9339WS00 Mfr#: AK-CC7129BP01
Ultra compact and low noise cooler for Intel Core 2 Duo and Core i3, i5 CPU's. The low profile design with embedded fan makes it a perfect solution for Thin mini-ITX, HTPC and SFF systems.
Aluminium heatsink and twin ball bearing fan ensure high efficiency and long life. High engineered multi directional aluminium heatsink maximises heat dissipation and PWM fan provides optimal CPU, motherboard and VRM cooling with minimal noise levels.
Pre-applied spring-loaded screws and motherboard backplate guarantee safe retention. Pre-applied high performance thermal compound ensures clean and easy installation.
  • Hi-engineered aluminium heatsink
  • Multi-directional fins for maximum system cooling
  • Embedded 8cm PWM fan with long life twin ball bearing
  • Pre-applied spring-loaded screws and motherboard backplate
  • Dual mounting for Intel LGA775, LGA1150, LGA1155 and LGA1156 platforms
  • High performance thermal interface is pre-applied
  • Total height only 21mm
  • Socket type Intel LGA775 , LGA115X
  • Cooler dimension 85.2 X 87.2 X 21 mm
  • Heatsink material Aluminum
  • Weight 154 g
  • Installation Screws and retention backplate
  • Fan dimension Ø75 x 10 mm
  • Fan speed 600 - 3000 RPM (PWM controlled)
  • Max airflow 23.45CFM
  • Max air pressure 1.81 mmH2O
  • Noise level 30.75dB(A)
  • Voltage rating 12V DC
  • Bearing type Twin Ball
  • Fan life expectancy 50,000 hours
  • Fan connector 4pin PWM
Akasa AK CC7129BP01 - processor cooler
Processor cooler
Compatibility
LGA775 Socket, LGA1156 Socket, LGA1155 Socket, LGA1150 Socket
Heatsink Material
Aluminium
Fan Diameter
75 mm
Fan Height
10 mm
Fan Bearing
Twin Ball Bearing
Rotation Speed
600-3000 rpm
Air Flow
23.5 cfm
Noise Level
30.8 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
8.52 cm x 8.72 cm x 2.1 cm
154 g
Processor cooler
8.52 cm
8.72 cm
2.1 cm
154 g
Heatsink & Fan
Compatible With
Heatsink Material
Aluminium
Fan Diameter
75 mm
Fan Height
10 mm
Fan Bearing
Twin Ball Bearing
Rotation Speed
600-3000 rpm
Air Flow
23.5 cfm
Air Pressure
1.81 mm
Noise Level
30.8 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
