Product
Brand
Akasa Intel LGA 1366, 1156, 775, AMD AM2/AM3  Multi Plat  3HP Cooler, 92mm PWM Fan
Quicklinx: 67BCWS00 Mfr#: AK-968
X4 is an all new multi-platform CPU cooler which has been developed from the hugely popular AK-965 heatsink. Now compatible with four different mounting types to make it suitable for all current AMD and Intel processors.
The low noise X4 utilizes three long heatpipes precision embedded in a copper base for rapid and even heat absorption and transfer to 45 aluminium fine fins. The PWM fan provides quiet controlled performance and efficient heat dissipation. X4 is designed to incorporate automatic VRM cooling (VRM - CPU Voltage Regulator Modules located on the motherboard), this is an important function that helps to keep your PC stable.
New design akasa (patent pending) Easy Select Clip with Intel reference push-pin retention is used for no-hassle mounting on Intel LGA775, LGA1156 and LGA1366 platforms - no backplate is needed. AMD Sockets 939, AM2, AM2+ and AM3 are catered for with a cam-lever clip for safe and easy attachment. Performance thermal compound is supplied.
  • 3 long heatpipes ensure superb cooling performance
  • Smart design enables VRM cooling
  • Low noise fan with PWM control
  • Quick installation with akasa Easy Select Clip
Socket type: Intel LGA775, LGA1156, LGA1366 AMD Socket 939, AM2, AM3 Cooler dimension: 135 (H) x 109 (W) x 90 (D) mm Heatsink material: Aluminium and copper Weight :458g Installation: Push pins (Intel) Cam-lever clip (AMD) Fan dimension: 92 x 92 x 25 mm Fan speed: 600 - 2500 RPM (PWM controlled) Max airflow : 47.68 CFM (80.82 m³/h) Max air pressure : 2.56mm H2O Noise level : 17.0 - 29.5 dB(A) Current rating: 0.21A Voltage rating :12V DC Bearing type : Sleeve Fan life expectancy : 30,000 hours
