The long life two-ball bearing fan draws the cool air though the fins and extracts hot air to one side to support chassis airflow. Dual mounting with spring-loaded screws and motherboard backplate guarantee safe retention. Thermal compound and LGA775 / LGA115X backplates are provided.
- Active LGA775 & LGA115X cooling solution
- Side blow fan
- Solid copper heatsink
- Reliable and long life twin ball bearing fan
- Akasa AK CCE-7107BP - processor cooler
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- Compatibility
- LGA775 Socket, LGA1156 Socket, LGA1155 Socket
- Heatsink Material
- Copper
- Fan Diameter
- 77 mm
- Fan Height
- 15 mm
- Fan Bearing
- Twin Ball Bearing
- Rotation Speed
- 1200-5500 rpm
- Air Flow
- 11.83 cfm
- Noise Level
- 45.99 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support
- 8.99 cm x 8.62 cm x 3.05 cm
- Product Type
- Processor cooler
- Package Content
- Thermal paste
- 8.99 cm
- 8.62 cm
- 3.05 cm
Heatsink & Fan
- Compatible With
- Heatsink Material
- Copper
- Fan Diameter
- 77 mm
- Fan Height
- 15 mm
- Fan Bearing
- Twin Ball Bearing
- Rotation Speed
- 1200-5500 rpm
- Air Flow
- 11.83 cfm
- Air Pressure
- 20.66 mm
- Noise Level
- 45.99 dBA
- Power Connector
- Rated Voltage
- 12 V
- MTBF
- 80,000 hours
